RCU Forums - View Single Post - Remove fly wheel and go from 3-blade prop to 2-blade prop will it increase power?
Old 05-04-2016 | 12:07 PM
Doug Kaiser
Default Remove fly wheel and go from 3-blade prop to 2-blade prop will it increase power?
For my Alpha 40, I have the Evolution Power System which is basically an Evolution .46 engine that comes with a flywheel and a 3-blade prop. The flywheel and prop are supposed to help the engine run more reliably (smoothly) at lower throttle (per the manual). My question is if I remove the flywheel and go to a 2-blade prop, will it increase the power? I don't need the lower speeds (throttle), I'd rather have the power.
