RCU Forums - View Single Post - Pattern Weight Limit Why?
Old 05-05-2016 | 08:13 AM
Dave Harmon
Originally Posted by big_G
I agree. I see pilots spending hundreds of not thousands of dollars with carbon fiber parts and expensive in-runner gear drives just to make weight. If the limit was 5.5 kg...about 12 lbs., the cost to fly would come way down.
Originally Posted by R3d Ryd3r
Hey guys, I am wondering about the weight limit for AMA and NSRCA Pattern planes? I know that in the sportsman class, no one at a regional contest is going to weigh your plane and kick you out for being over the 11lb limit. But at the higher classes, and at the NATS, your plane must be below the limit to be legal. If someone from the AMA or the NSRCA would care to explain the reasoning behind the 11lb weight limit, I would like to hear the answer. It seems to me that with modern electric components, you have about 6lbs of airframe including wheels prop/spinner, and about 5lbs for motor/ESC/Servos/Battery/Etc..... If your plane is heavy it will not perform the same as a lighter plane, but why make the bar so low and restrictive? is it just to drive up the cost? Why on earth would you drive the cost up for everyone? Does not make any sense to me.....
Not really......
I have a BJ Craft Essence that weighs 4860g ready to fly and is a fully competitive airplane in FAI as well as AMA schedules.
I also have a BJ Craft Nuance that weighs less than that.
These two airplanes do not have a scrap of carbon fiber or in-runner drives.
I did splurge a bit though and use a Mejzlik 3 blade prop.
I am not the only one....there are many guys that have these airplanes and I would guess that they are all well under the 5kg limit.
You would be amazed at how well they fly compared to almost anything else....properly setup though....setup is everything.
Dave
