wing plans are easy,provided you supply the spar material dimensions,and whatever stringer dimensions...ie,1/8 x 3/8, and location.Bottom line...wing plan $20.00 ca.As usual,a full plan(one side fuse,and empenage,to be mirrored for the other side,you print at a store $50.00 CA.all made in Dwg format. I use a mirrored, one half fuselage format, to ensure aligned fuse and empenage.In a foam core,the location of spars and associated connectors,and ply wing ribs ,is imperative.
