RCU Forums - View Single Post - VVRC 20cc idle help
Old 05-06-2016 | 08:57 AM
ahicks
You can always get an engine to slow by making it richer. That would be my first bet on a new engine.
That said, there's a slight possibility the brass throttle disc may be loose or not centered properly in the carb bore, making it impossible for the carb to close as designed. An intake leak (carb gasket, cracked carb adapter, etc.) could also do what you describe.
