Hi Doug
Are your pushrods wood sticks with wire ends? If yes then having the wire move through a tube is unusual and something I would not recommend
If the pushrod is a .plastic rod that runs inside a plastic tube which is fixed at both ends then these are usually very free running and I would look for misalignment or even physical damage before I would try lubrication.
