RCU Forums - View Single Post - Engine differance
Old 05-09-2016 | 06:53 AM
buzzard bait
Another way to look at it is the weight of the engine you want to replace. Also ground clearance and space for installation.
The 61s of 30 years ago usually weighed in the range of about 18 to 21 oz w muffler. The OS 70 to 81 alpha, Saito 82, 91, or 100, or YS 70 to 80, or equivalent all fit that range; power will range from a little less than the old 61 to much more. They are longer than 2 two strokes which may caused installation problems. They turn larger props, which sometimes cause ground clearance problems, though you can usually fix that by increasing pitch to keep down the diameter, or with 3 bladed props.
More recent 61s weigh more like 24 to 26 oz and generally make more power than older 61s. For those engines, you definitely want at least a 91 4-stroke to get equivalent power, or any YS But you could also go with much more powerful 4-strokes without a weight penalty, like the OS 110 alpha (discontinued?), Saito 125, YS 110-115 which are all very strong engines. Then prop clearance and installation might limit you.
Jim
