Originally Posted by
gunradd
Well Mike if you question your radio equipment then I would try and either get telemetry and find someone that can lend something to check it. I doubt its the radio system also since your turbine is not going to fail safe then its really unlikely its your radio system. Also do you have the fail safe set and if so is it set to fly straight?
I would say its your conditions and might be an updraft in that area of the field.
Thanks, I have had this DX18 for so long. And it also seems to be a wing rock, never a fail safe or elevator set up moving. I have a few extra TM1000 laying around, I guess setting one up to check the frame loss wouldn't be a bad ideal. Thanks,
I can a updraft mess with a jet at 200mph?
