RCU Forums - View Single Post - First timer here
Old 05-09-2016 | 09:51 AM
JollyPopper's Avatar
JollyPopper
The suggestions so far are spot on. I don't see in your list of items included that you got a transmitter with it. If that is the case, you will either need to find a used transmitter that matches whatever channel receiver is in the plane or buy a transmitter with channel of your choice and change the crystal in your receiver to match the transmitter or buy a totally new, preferably a 2.4 system, to fly the plane. The airplane itself looks to be pretty well done as far as I can tell from the pics. The pics act really strange when I try to expand them so I cant' tell much. My opinion of the engine is that it will be enough to fly the plane kind of scale like but not enough to really haul it around with much authority. The FP series of engines were wildly contradictory contraptions. While being really easy to start and having a very long life span, they were at the same time very low on brute power. They were very good engines in the proper application and I still have and use a couple of them routinely, but it will have all it can handle in this plane.
