RCU Forums - View Single Post - TeeDee .049
Thread: TeeDee .049
Old 05-09-2016 | 11:24 AM
Pond Skipper's Avatar
Pond Skipper
Yes there is the Low Compression Head and the High Compression Head and mild modifications over the
years that's the jest of it. The TD type glow plug will have a knurling ring around the top. The low compression
heads have no knurling marks just smooth on top. The TD High Compression head will give you a good jump
in rpm.
2 head shims with a stock glow plug and a 6x3 prop sounds about right with 25% nitro.
Did it run steady with the back plate pressure? Agree with Chuck you should fly it and
enjoy! It may loosen up a bit in the air and I would imagine up to 23k unloaded is possible.
Post a vid if you can = )
