RE: Aresti, Funtana, UCD3D ??????
I've got the Funtana.
Mental
Great model that goes together well. Don't go with the recommended engines they're too small, yes I made that expensive mistake. Most go with a saito 100but that is top wack and you can get away with less. An OS46FX flies it but not as intended, as in it won't pull out of prop hang.
Look at some of the other theads here there's loads of info. I guess it depends what you want it to do.
sj.
