RCU Forums - View Single Post - Jettronic Double Action Valve help needed
Old 05-10-2016 | 01:01 PM
FenderBean's Avatar
FenderBean
Default Jettronic Double Action Valve help needed
Hey folks put two of these on my F-14 with the intent to use the throttle function on the down side of the gear to hopefully stop breaking locking cylinders when the gear comes down. I managed to add a 8 sec down pulse but the default is 3 secs both ways., so I need some help getting the gear up pulse turned off or as low as possible to get max push up.
I have the lights set to green for down and red to up, it says press the green for 3 secs on power up, this allows me to adjust the down pulse very easy but what I cant figure out is how to adjust the up. It says to place the switch momentary position to adjust but that doesnt seem to work.
Should I turn on the receiver with the radio switch set to gear up? I tried this once and it turned on the fail safe function which I dont need. I think its telling me to press the green button on power up for 3 secs then flip the gear switch to the up then select red button which decreases the time, is this correct?
