Originally Posted by
mattster1971
Do the Wraith and the Honcho use the same axle? I thought the Wraith uses an AR60 and the honcho uses the one from the SCX10? or am I wrong? The fit issue may be because you purchased the wraith steering link set and are using it on a hybrid wraith/honcho vehicle if I am reading the thread description properly.
No they dont.....You are right wraith uses the AR60 and the honcho uses the scx10 axles, but I used wraith axles on my SCX10 honcho to get a wider stance....they call it a wroncho......so when I need something axle wise I need wraith stuff not scx10.....it appears the hot racing steering link needs a little bending to fithe they should probably fix that lol.
