RCU Forums - View Single Post - Laminate balsa?
Thread: Laminate balsa?
Old 05-01-2002 | 11:53 PM
kevin mcgrath
Default Laminate balsa?
You are welcome.Laminating is one of those little building skills that you learn along the way,and it can be a little tricky,but its one good way to build up strength in a structure while keeping the weight down.You will often hear the term doubler in relation to laminations which makes sense when you stop to think about it
