Laminate balsa?
I dissagree on the "not using water based glues" above. I use capenters glue all the time-much better than the CA's-and it works great. If you have a large area, it is a good idea to weight down the assembly until curred or dried no matter which glue you use. Properly done, laminates are much stronger for the same weight and solid pieces.
