Originally Posted by
Bobneal1
Guys,
I need more than 3 rates for elevators and ailerons. I actually need two different expos for the same travel rates, one for gyro on and one for gyro off. I have flight modes set up and I have five of them. What I want is low rate elevator with say 20% expo gyro on, then low rate with 40% expo with gyro off and the same for all three rates, low mid and high. I have the gyro switching off and on with my flight modes, I just can't figure out how to vary the expo.
Bob Neal
Bob, you can set that up in flight modes, just send it zero gain on the ones you want the gyro off. you can make it announce each flight mode two.. 5 modes takes two switches however. It might be easier to use 3 flight modes, and a separate high/low/off gain
I have a 'gain on, gain off" switch that I use in each flight mode as needed.
