Wonder if the low speed needle is too rich or too lean? Want a dead simple trick that works immediately?
It's simple and easy to judge.
After the engine has settled down into idle, pinch the fuel tubing closed and listen. When it runs out the very little fuel left to it, it will either stop or it will speed up and stop. If it speeds up before stopping, the low speed was too rich. Adjust and test again.
