RCU Forums - View Single Post - Prop keeps spinning off!
Old 05-17-2016 | 05:40 AM
jester_s1
Moderator
Are you using a spinner with a plastic backplate? If so, that's your problem. Cut a piece of open mesh plumber's sandcloth or drywall sanding sheet to make a washer to put between the prop and the backplate. That will add considerable friction there, enough to stop the prop from spinning loose.
