RCU Forums - View Single Post - OS120 S-E Timeing question
Old 10-22-2003 | 08:02 PM
William Robison
Default RE: OS120 S-E Timeing question
Moose:
Quick and dirty: Stick the cam and pushrods in, then with your finger on the push rods to feel their movement, play with the cam setting until you feel one rod coming up and the other going down as the piston hits top dead center. This will, of course, be every other turn of the crank if you turn it through.
Then reinstall the cam cover and bearing, with oil, of course, install the rockers, and eyeball the overlap point again as a double check.
If it's right, adjust the valves, oil the rockers, finish the assembly, and go fly.
Bill.
