Thomas, thanks for taking the time to help me with this. I am not seeing the Xycoy when I press the "Auto" and wait 5 mins. The mapping seems to work ok to the throttle. When I use the Jet Central Data terminal with the DS-16 I can train the transmitter and the turbine should operate ok. I did not start it but the Pulse = readings responded to the throttle. I've double checked my connections and I believe following the Xycoy FC inputs/outputs. As a test I took another Xycoy FC and it is doing the same thing.
A side question is the receiver status lights both come on. I thought I read with Jeti only the active link would be ok?
Anyone input on the battery selection? Is using the Lipo ok with the Li Ion? I know this is not effecting the issue I am having now.
Again thanks, I am now up to page 64 of the forum and learning. I think the mixing part will be ok for me, for some reason this seems easy and the Jeti makes it easier.
