I resolved the problem. I thought that the turbine throttle in and out on the FC must be used so wired it that way. It did reference for later use but I thought that meant the twin engine capability not the single engine also. I was further misled when I looked a few you tube videos and saw the turbine in line was being used but apparently that was just for power if you were not using tele to get power. Was trying to get the turbine and ECU sinked and had not started on the tele part. Anyway working now and I think I am going to really like the Jeti system. It was truly designed for tele and other advanced networking where the others seems was an afterthought. Again thanks
One question to anyone using the Xycoy FC and Royal or others that have GPS are you using both the GPS in the FC along with the GPS in the PowerBox?
