You could count the clicks on the trim as you move it back to zero. Then pin or mark the position of the control surface. After this remove the control linkage. Now move the trim in the opposite direction the same number of clicks.
Edit-Adjust the linkage here before hooking backup to the control surface
Hook the linkage back up without moving the control surface from its starting position. Move the trim back to zero and your ready to go fly.
