After you adjustments to center the trims , you will need to retrim the plane ,once again ,and possible tweek the adjustments some ,from future flights
Keep in mind that changes in temp ,can effect your control rods and airframe that will expend and contract ,( metal and balsa wood ) especially if you use the sullivan metal rods in the red sleeve ,which is my control rod of choice with hays clevises
Put the control rod ,as close to the inside of the servo horn ,while still getting the control throw you desire ( the same amount of throw ,at a slower interval ,so more control )
The difference of flying a plane in the winter and then again in the summer ,can change the way a planes trim adjustments will require centering
A simpler method is to mark down the trim locations ,and be sure they are all set correctly before your take off .and fly the plane that way
As long as the trims are fairly close to the center ,leave them be and fly the plane ,due to the changes in temp that will always be effecting your airframe for as long as you own it
i fly planes that are some of my first and over 20 years oold
