I followed on from what you said ext2Rob and it worked. I turned on the Th. Rev switch to reverse and moved the trim but the wheels stayed in reverse after moving the trim to the end of both sides so I kill switched the esc with the th. rev switch in reverse. Then as I turned the esc back on forward work's so I'm going to my back yard to record it.
