Originally Posted by
Dave Wilshere
That's wild !!
Do you think the circumference of the intake could be around 270-ish mm?
JetFan just came out with a 100mm fan that does around 300 watts to a lb after 13 lbs which is the most efficient for the size that doesn't cause ones ears to ring.
... 2 x 12.5 static thrust with ~ 10% flow loss and ~ 22lbs installed estimate.
I figure 6 mins pegged at 10c and that's without using HV or graphene packs to make up for the voltage drop.
What's the weight with gear?... I'm sure its mentioned in the thread but its over 200 pgs
Thx in advance for any input
Saw a couple of em fly and and have to have one on the bucket list
