Interesting that the controls are reversed between those two transmitters! This was so typical of early small R/C companies. I know that no two receivers I make are identical because I get quite an assortment of different brands of caps, transistors and components. This is true of all small manufacturers, and in addition, they typically will make changes within a certain model as needed, without changing the model number or revision.
