Originally Posted by
wildnloose
If I just need a new mount then I'm ok with buying one. They are not that much.
Thanks guys.
Oh, forgot to ask another thing. One of my fuel valves was bad, so I didn't use it on the propane start. But it started without issue. Do I need to use a fuel valve on the propane start side?
All good ideas above. I have used gasket paper as a spacer for the mounting straps.
While you can operate a propane start engine without the solenoid fuel valve, it is definitely not recommended.. The ECU shuts this valve whenever the engine is not actually starting, or running. This greatly reduces the chance of liquid fuel ever getting into the combustion chamber, and causing a hot start. It is actually a very valuable safety device.
