The stock gear is designed to have 1/8" packers under the mounting lugs. (C-36-2) There are pre cut plywood rectangles with holes ready for the behotec gear.
Depending on the lug thickness/mounting screw type, you should be able to pack. With CSK screws you have more clearance on the cover plate
