Originally Posted by
Bob_B
Wayne there are 5 inputs/outputs on the cortex and each can be used to stabilize any surface
so you can have two Seperate elevator input to the the cortex and then to separate elevators allowing you to reverse one as needed in the Tx. Then when you do the learning phase of the setup the gyro learns your radio setup.
I have a flying jet that I installed cortex in, rudder, steering, elevator are correcting surfaces wrong way, but ailerons is being corrected properly. It is a intro boomerang. One elevator, two rudders into one channel. Reversing channel in DX-18 causes wrong deflection of control surfaces. If during setting up cortex, I pull elevator and then push, and left rudder then right rudder, it corrects it in proper direct, but that is not the order the manual says to use?? Any ideas, is changing order during set up alright to gain right direction?
