I glued on a piece of 1/32 aircraft ply to the LE of the intake to save the straight edge. The plywood had some glass and paint on it from a previous wreck of something. I filled in the underside of the tops of the intakes. The pieces needed a little shim to get them flush. I also glued some sticks between the sheets to stiffen them. The outboard intake walls got added and the angle cut. It looks a little more like a Vigilante.
