RCU Forums - View Single Post - Demon Cortex Gyro question
Old 05-29-2016 | 11:29 PM
  #456
Mi-25
Originally Posted by twhite6728
I have a flying jet that I installed cortex in, rudder, steering, elevator are correcting surfaces wrong way, but ailerons is being corrected properly. It is a intro boomerang. One elevator, two rudders into one channel. Reversing channel in DX-18 causes wrong deflection of control surfaces. If during setting up cortex, I pull elevator and then push, and left rudder then right rudder, it corrects it in proper direct, but that is not the order the manual says to use?? Any ideas, is changing order during set up alright to gain right direction?
Did you install your Cortex with the correct orientation as per the instructions?? If you have installed it differently you will get differing control surface movements - you need to program any different mounting orientation using the Cortex PC Software.
