I highly recommend you make what ever channel you are using for the gain is lower the travel to 0 so the gyro can't go into heading mode.
In the setup on the radio you will have center travel is off and one way is heading mode and the other direction is normal mode. The heading mode is only used for hanging on the prop in 3D planes.
