Originally Posted by
twhite6728
Top of picture is front of jet. Hard to see it there but correct installation direction
F1 Rocket
There are only two things that will cause what you are discribing.
Either the mounting orientation is not set correctly in the system or you are moving the TX sticks the wrong way when you are doing the stick programming sequence. Nothing else will cause this behavior. Also, please do not modify the published stick programming sequence. It must be; right ail, left ail, down elev, up elev, right rud, left rudder. Remember to remove the programming jumper before you shut off power. If the above does not result in correct movement then the mounting orientation is not set correctly. Please do not fly until you have this figured out.
if you would like I can take a video of me using published sequence and show the incorrect surface correction, and nothing has been changed via PC as I don't have the USB cable for the Cortex.
