RCU Forums - View Single Post - Demon Cortex Gyro question
Old 05-30-2016 | 11:46 AM
  #469
rcjets_63's Avatar
rcjets_63
Hi Ted,
I'm glad you posted the video showing the lights and the transmitter. The video shows that the programming is done out of sequence (you've started too soon). You have to wait until you get the double green pulse to put in the first stick movement (right aileron). The video shows the red initialize pulse (21 seconds) and you put in right aileron (24 seconds), then the gyro gives the green double pulse (25 seconds) but you then put in left aileron since you started too early. The rest of the programming sequence continues, but one step ahead.
Try it again, but wait for the green double pulse before you start the stick movements and you should be fine. Give me a call if you need some more help.
Regards,
Jim
