Based on a stretched Revo 3.3 chassis that is stretched to 17.75'' wheelbase. Brushless power running on 4s using SMC 9400Mah 2s lipos. The 2 speed Summit transmission has the LEM dog carrier installed to take out the slop that the weak stock one has. 40 series tires are cut to fit the 1/5 scale beadlock rims. It uses led lights for night time use that run on both 2s and 3s power. HV power to the 475 oz hitec servo and the alturn micro for the transmission are fed througha 10 amp Castle bec.
