RCU Forums - View Single Post - UMS Evolution Radial Care and Operation
Old 06-03-2016 | 04:38 PM
  #1883
Pretendpilot
im about to start this thing up and need some guidance on tuning the carb...
I know the HS needle is the big knurled one, but that's all I know. I don't know where the LS needle is or the idle adjust, or if there is a mid-speed adjust. I don't know what to do 1st.
...are the factory settings on the OS carb good to start with (however they are set when purchased)? is the startup procedure in the manual good (but it assumes the EVO carb)?
I have the CH ignition, the os carb with CH adapater. running pure methanol with klotz super technoplate. evo exhaust ring.
ill be tuning on a stand. ...I noticed chorner and others mention a carb orientation - not sure what that is about. mine has the HS adjust facing to the right when viewed from behind (cockpit view).
