Front plate from the front with a wood coffee stirrer to clean out the holes for the followers. Two followers, upper as it came out of the engine, lower cleaned. The ground rod at the top had to be used to get the followers out.
Technique I used required a number of swabs with the stick, wipe out the gunk, repeat.
Top of pic shows the PIN FOR CRANKCASE AND FRONT PL:ATE ALIGNMENT (47001100), which does with the title says it does. It had to be cleaned too.
