Originally Posted by
smitty4980
Hey Charley, I ended up getting a new fuselage which was a bit expensive but I figured the whole amphibian experience was worth it. I peeled off the decals and reapplied them to the new fuselage with 3M 77 spray adhesive. To prevent chopping into the fuselage again I made a temporary strut between the motor and body with a popsicle stick. It prevents excessive flexing of the engine pylon if I land too hard. Keeping up the airspeed during landing is my biggest challenge but I'm doing much better. It's a big switch from my high wing trainer that will glide forever with the throttle chopped.
Glad you made a decision and it suits you.
That strut sounds like a good idea. Did you paint it white?
On landing, I like to keep the model in a nose-up attitude all the way to touchdown. It may take a touch of throttle to maintain this. After all, you want to "set" the model in landing attitude with the elevator and use the throttle to control the rate of descent.
CR
