Originally Posted by
redtail
Help - another rookie question. I have a UAT with a large fitting (6mm) leading to the pump. I am installing a Jet Central Bee. The supplied shutoff valve fittings are only 4mm. Not sure how to fit the 4mm tubing to the 6mm UAT fitting. Are there UAT's with a smaller pump fitting (4mm) that would certainly solve this problem. Thanks everyone. Chic
I don't use a manual valve as here is a solenoid already doing the work. Adding stuff adds potential leak points. The thing about going 6mm to the pump is to reduce pressure drop on the suction side and put all valves, filters, solenoids, reductions etc on the pressure side. Even top grade builders forget about this and adds up many connectors on the way through the fuel system. I always try to keep the lines as uncut as possible.
