Originally Posted by
slither
Failure in the air does not rule out starters as an issue...
No, probably not, but a failure due to a starter and hydro-lock would probably manifest itself before getting off the ground.
For those that have done the Walbro conversion, I am having some problems getting it tuned.....(I thought this would go away with the walbro)....what needle settings did you end up with. I don't know what they were to start with, I shoulda checked....but I am getting some odd symptoms from bad tunes. I am good at getting the 2-strokes tuned, but this is not behaving the same...
