Both. It's the new "Boomercanard". It can loop within its own length, forward under power, backwards from a vertical slide. You used to do that full scale back in the day didn't you?
Goose, I see a Cortex in your plane. What's the JR Ring Gyro for?
Jerry Crow, CD, LMAI
Ron Colbert, Asst. CD, LMAI
Roger Shipley, Organizer
www.route66jets.com
the JR gyro is eye candy from the past mostly, but its hooked to the nose wheel, and it works pretty well since I'm such a crappy pilot, I need all the help I can get. LOL..
My full scale aircraft is down for an engine rebuild, but my hope is that I get it finished in time for R66 to fly out.. I will have to let you guys know.. I will be flying to Galesburg for the stearman fly for a couple days first.. IF I am able to fly out, I will need to coordinate with Jim for a Hangar for a day or two if able.. I would rather hanger it if able.weather depending... It can share with the jets if needed since its high wing, you can put planes all around it.
