Originally Posted by
nicoladestro
Hi. I am going to buy a Carf spit too by the end of this year. I am searching for the right engine. I really love inline engine (4T) like Valach or Kolm but they are very expensive.. So i could choose the DA100i but searching on the web i have found an old engine revisited with GAS ignition: the MOKI G360. It's a 2 stroke inline engine that has about 7,7hp and is very light. Have you some drawing of the CARF cowl in order to check if the engine can fit inside ?I think it is a very small engine but i think it has the drive shaft a little bit short... here is a picture of the engine. Thanks. Nicola
I don't have any drawings of the cowl. It's basically a rounded flat shape on top, but it tapers up and in at the nose. The engine above would require a large hole on the bottom of the cowl for the front cylinder.
But why not buy a scale plastic model of this airplane and then measure the cowl, multiply it by the scale factor from the plastic model to the Carf kit (23%) and the4n you will see if you would be happy with the size of the hole in the bottom of the cowl.
