RCU Forums - View Single Post - Battery requirements
Old 06-15-2016 | 05:48 AM
Hydro Junkie's Avatar
Hydro Junkie
Originally Posted by jester_s1
Those are low demand servos. You can probably get 5 safe flights out of a 700 mah pack. I'll second the suggestion to go with a 6v pack, especially if you are using Spektrum radio equipment.
Agreed, since the 148 only draws .8 milliamps when idle, the load to the battery packs is almost nil at 3.6 milliamps plus the receiver draw, 30 milliamps at rest using a Futaba R2004GF in this example. With a combined load of 33.6 milliamps at rest, you could leave the receiver on for 20+ hours before the battery pack failed, if fully charged. Obviously, when in flight, the load is greatly increased. If you were using the higher performance and/or digital type servos, all specify that they have a high current draw so a larger pack would be needed for equal flight time. One thing to be aware of is that with the 148 servos, if you use a 6 volt pack, the speed and torque are both 25% greater. The speed won't be an issue as it's only .06 seconds faster lock to lock. The higher torque would, however, allow the use of larger control surfaces or require a lower current draw for smaller ones
