RCU Forums - View Single Post - Battery requirements
Old 06-15-2016 | 11:33 AM
Hydro Junkie's Avatar
Hydro Junkie
Originally Posted by wnewbury
If he had digital servos, wouldn't that increase his requirement? Don't digital servos require much more electricity than analog?
I actually addressed that in the middle of my last post but I will point it out in the cut and paste below:
Agreed, since the 148 only draws .8 milliamps when idle, the load to the battery packs is almost nil at 3.6 milliamps plus the receiver draw, 30 milliamps at rest using a Futaba R2004GF in this example. With a combined load of 33.6 milliamps at rest, you could leave the receiver on for 20+ hours before the battery pack failed, if fully charged. Obviously, when in flight, the load is greatly increased. If you were using the higher performance and/or digital type servos, all specify that they have a high current draw so a larger pack would be needed for equal flight time. One thing to be aware of is that with the 148 servos, if you use a 6 volt pack, the speed and torque are both 25% greater. The speed won't be an issue as it's only .06 seconds faster lock to lock. The higher torque would, however, allow the use of larger control surfaces or require a lower current draw for smaller ones
