Been there, done that. The engine will need a nipple installed in the crankcase for the fuel pump to get it's pressure/vacuum signal for the carb's fuel pump. This will involve pulling the engine down so you can clean up the metal particles left from that operation. After that, you just reassemble and you're good to go. Carb sets up exactly like the original.
