Marvel, ATF, or air tool oil are the standards. WD40 is fine but thin so it does a better job flushing than preserving. If nothing went down the carb or the muffler it should be fine. keep the throttle closed block off the exhaust and clean the dirt off the outside. Almost every trainer on the market flies just fine. Make sure all the wires are ok on the flight pack.
