No problem guys. here it is. i could have made them longer but i still have the plastic bearing retaining tab in the rear axle. i can still add more inside the lock out but i wanted less weight in the back. the beef tubes are in the front and the COG is low. helps to keep the tires on the ground more.
in the rockslide axles there is not a retainer so you can do this the whole way down the axle shaft and in the sxc10 if you grind the tab away. the thickness of the solder is important. to thick and it won't work.
