Originally Posted by
krokodyl
Also, do you guys recommend to use the reciever after the crash? Thr case popped open, and a bit of plastic came of from the shorter antenna.
Especiall since the avistar does not self correct (i think), so incase of signal loss i would lise another airplane.
For me I draw the line at physical damage such as you described for reuse of the Rx regardless of any range test. Damage such as that often results in two things either a cracked ceramic filter or a cracked circuit board/trace that may be intermittent .
Its important to understand the so called self righting tendencies of some airplanes is perhaps only in the first 15 or so degrees of roll. And will certainly not save an airplane if the signal is lost. If signal is lost that airplane is going to crash.
John
