I have updated post 245 with the updated map, it can be downloaded as a PDF.
Just to clarify, camper positions 14A through 28A are under review by the airport manager, these positions are in front of hangers in which there might be aircraft owners who may want access to there aircraft.
If this is the case then the campers assignments in the affected areas will need to be relocated on the map, most likely to the tarmac area.
Also the Tent positions (Tent #1 and #2) are being verified by Lewis this week.
The map was updated to show the pop up canopy area.
Thank you for your patience and understanding in these matters
