Originally Posted by
skywarrior
Hi,
i have the boards and some questions
There's is is a small round thick washer with small central hole.Is this used on the CARF size gear motor
It says if the motor is revolving the wrong way for up or down then reverse the supply.
does that mean turn the board 180 so the supply is reversed to the board or ?
Regards
David
Hi David,
I didn't use any washers so I'm unsure what kind of washer you have. Please refer to the picture below to show the installation. Just make sure the board is not touching to motor casing.
If the gear motor direction is wrong just reverse the cord while connecting it to LGC15 unit: simple and no need for any further soldering.
Regards, Ilkka
