Is that truck 2wd or 4wd? I have been seeing conflicting answers. Also does it have a low center of gravity chassis? It looks like they utilize the older High center of gravity chassis but like i said some of the info that i have been finding isn't matching up. If you can answer those two questions then i can give you a relatively definitive answer. The low center of gravity chassis has a flat bottom from front to back were the high center of gravity is roughly A-frame shape when viewed from the side.
